A Little Nat Help Please
I've finally got it working!
I've configured my static internal IP address. Now I want to have it work from the outside world of my WIFI.
I've configured my Router's PORT FORARDING rule on my Verizon ACTIONTEC Router. I added the following rule.
192.168.1.60
Destination Ports 81
TCP Any -> 81
UDP Any -> 81 All Broadband Devices Active
( Currently you can see my static ip is 192.168.1.60 )
Now I know I need to change the Arduino code to from 80 to 81 LINE WebServer webserver("",80)
My question is in the IPHONE App. What IP address do I use?
Is it the Router DHCP address? 173.xx.xx.xx
I know the DHCP address can change, so I read somewhere that I need to name it and somehow register the name with the current DHCP address. I'm not sure where? I plug the name into the code so the name will get resolved to the correct address right?
It is a neat app. My first Arduion project so everything is new. I used a KA05 IO/ shield and it seems to work fine for both my door status pins 2,3 and relay's 8,9 I got two DLINK camera's and that part is working great. I'll post some pic's when everything is working on the projects link.
Thanks for your help here...
192.168.1.60
TCP Any -> 81
