Not working
Not working
Postby gio_dude » Sat Apr 11, 2015 8:03 am
Are there any reported issues with the newest AirPort Extreme. I feel like I set it up right and can't get it to work.
I'm stuck at the check in web browser step haven't even got to the app.
Sorry I forgot I'm using an xboard, Mac on 10.10 and newest AirPort Extreme
gio_dude
Re: Not working
Postby gio_dude » Sun Apr 12, 2015 3:01 am
So figured out that latest version of safari doesn't display an xml format like the guide asked for.
Firefox worked fine. So I moved on to setting up the iPhone app and I keep getting could not connect to the server error. On wifi and on lte.
I also setup an dynamic DNS to see if it helped and it didn't. I used no-ip for the ddns. No matter what I try I still can get it to work.
Any help would be much appreciated
gio_dude
Re: Not working
Postby support » Mon Apr 13, 2015 4:30 pm
We haven't heard of any issues with AirPort Extreme. Are you using this over wired ethernet or did you "hack" some sort of WiFi bridge configuration?
Re: Not working
Postby gio_dude » Mon Apr 13, 2015 9:18 pm
Wired Ethernet.
gio_dude
Re: Not working
Postby support » Sat Apr 18, 2015 10:22 pm
I suggest you get your Arduino / XBoard configured in the most simplistic way and troubleshoot a very basic
setup. Then once that works, build on top of that ... So, 1) no dynamic DNS to start with ... 2) internal network
first (no internet), etc ... And then when that works add a little bit at a time so that when something isn't
working you why/what more easily.
Re: Not working
Postby gio_dude » Wed Apr 22, 2015 12:58 pm
This is where I'm at.
xboard plugged into router (newest airport extreme) router into charter cable modem (i think its an arris). nothing plugged into the relay or sensor just either net and power.
from my mac (wired to same router) type in ip address for xboard an get this
<myDoorOpener><status statusPin="3">Closed</status><status statusPin="4">Closed</status><challengeToken>Cyber1504441</challengeToken></myDoorOpener>
it looks just like the guide.
next step is to setup iPhone app. cool
url and password
I use my internal ip address for the xboard
http://xx.x.x.xx:port
and it works :D :D :D :D :D I here the clicking when i toggle it.
now I change my internal ip address to my public ip address
http://xx.xxx.xx.xx:port
It doesn't work. :x :x :x :x :x I have tried with and with out the port on the end. same result. could not connect to server
so this where I'm at. any help would be great.
gio_dude
Re: Not working
Postby support » Tue Apr 28, 2015 6:58 pm
You need to:
1) Make sure your ISP is not blocking incoming traffic.
2) Enable NAT port forwarding from your home router (external IP) to your Arduino (internal IP).
Re: Not working
Postby gio_dude » Sat May 02, 2015 9:40 pm
thank you for your help.
turns out my isp is blocking all my ports. anything i can do to fix it other then call charter.
Screen Shot 2015-05-02 at 9.30.00 PM.png (138.61 KiB) Viewed 22088 times
Screen Shot 2015-05-02 at 9.30.14 PM.png (116.69 KiB) Viewed 22088 times
Screen Shot 2015-05-02 at 9.38.29 PM.png (66.4 KiB) Viewed 22088 times
gio_dude
Re: Not working
Postby support » Wed May 06, 2015 7:57 am
Are they blocking all ports or just the commonly used ones? Because you could use, let's say external port 8888 and have it forward to port 80 internally. Just an idea ... If that doesn't work, I really don't know what you can do but change ISP or talk them into unblocking some ports ... Good luck!
Re: Not working
Postby gio_dude » Wed May 06, 2015 9:46 am
Thanks. I'm just glad to know know I wasn't doing anything wrong.
gio_dude
